Clutch bleed nipple (not grub screw) size ?
golfy1
Newbury
Hi all
Recently tried to remove the grub screw from the clutch remote bleed adapter (the black tube) on the right hand side of the bike. No amount of heat, WD40 etc would move the little ****. However I was able to remove the clutch remote bleed adapter, leaving a thread behind. Surely I could just use a standard bleed nipple in there instead? :nenau . If so, does anyone know the size please :thumb2 ( I assume something like a 10 x 1mm ?).
Thanking all in advance
Golfy :bounce1
