Clutch Bleed nipple.
AdrianS
Harlaston Staffs
Just a quickie:
want to fit a standard bleed nipple to the end of the clutch bleeding tube. I need to split the end part holding the 5mm allen screw from the end of the pipe. Before I break anything, is there any loctite between the 2 parts?
Cheers,
Adrian (1150R )
From memory there is but comes apart easy enough without any heat:thumb
Take the M10 plug away and install a standard M10x1 mm bleed nipple.
Pekka
:rolleyes::rolleyes::rolleyes:
