I've just replaced my clutch slave cylinder, which had failed and contaminated the clutch fluid. Clutch is working okay now - but I suspect there is still some air in it. And I can't get any clutch fluid to flow through the bleed line. Clearly the line from the master cylinder is working fine, so I suspect a blockage in the bleed line. Or even a faulty bleed line.
Does anyone have any suggestions how to clear it? Or should I just get a replacement?
Thanks.
Thanks.
