Squire padlock SS65CS
Joe narvey
UK
This is the padlock supplied by Almax to go with their huge chains.
I just watched a scary YouTube video of it being picked in just over a minute.
https://youtu.be/Tm1VahQNzVw
Question: is it frowned upon to attach bird and fox scaring type shotgun cartridge mechanisms to my bike or close by?
Scary indeed. But Almax now supply a different lock:
"The lock we use is not only Squires Flagship Stronghold SS65CS model, but the upgraded version known as the MOTO. This means not only is it bolted internally on assembly but also hydraulically pressed and secured with ball bearings. This ensures the maximum resistance to power tool attacks and pulling. We have also elected to use the highly respected Mauer Res 1 profile core as standard. This system requires the production of a key card to have additional keys cut as well as superior pick resistance."
I'd like to see how long it resists an angle grinder attack. Like your average tea leave isn't really going to bother is he? Yes if you wanted to open a lock without anyone knowing but I think when you see an empty space whare your bike was you'd soon realise what had happened. JJH
I just watched the "lock picking lawyer" do that one and the new SS80CS in approx a minute too. The ball bearings are for drill protection not picks. The Mauer 4 core is used in the SS80CS and it does look a lot more secure but it's over 2 kg in weight !
I may have to get my picks out later with SS65CS and see if I can beat the time :)
Several videos of battery operated angle grinders having a go but misleading as can't tell from video how much pressure is being put on the chain.
Do thieves pick locks anymore anyway? Seems they just have a battery angle grinder.
I would expect the path of least resistance to be the preferred attack but picking a lock in under a minute could easily be confused for using a key when being watched through CCTV or using a 'secure' car park.
In 30 years as a cop I never heard of never mind saw an active criminal who had the ability to use lock picks , even professional locksmiths use much less artistic methods to defeat a lock, although I have seen one old school locksmith using them rather successfully.
I've been involved in numerous incidents where people were arrested for either thefts, burglaries or for offences of going equipped and have never yet recovered a set of lock picks.
Angle grinders,battery drills , crowbars, bolt croppers ,slim jims, window punches, acetylene cutting gear, hydraulic cutters, pass keys, electronic scanners and so on but never lock picks.
They appear to have gone the way of 'Gentlemen Thieves , Jelly Men and black and white films '
Ditto:thumb. (But 32 years :augie )
......Angle grinders,battery drills , crowbars, bolt croppers ,slim jims, window punches, acetylene cutting gear, hydraulic cutters, pass keys, electronic scanners and so on.....
Bloody 'ell, if a tea leaf has to lug that lot around no wonder they don't have lock picks......no room :nenau
If I was usuing a angle grinder to cut a lock or chain I'd put enough pressure on to continue the cut and not bog down the blade. If it's slowing the disc I'd back off the pressure. I worked cutting slabs of granite and marble with a angle grinder and became quite proficient with said tool. JJH
I have an uncle that worked at prisons as a maintainable person ( at least he said he was working), I remember him being told how the guests/ inmates could make a key for a brief glance.
Agree if stealing a angle grinder or lump hammer approach may be easier but I'd expect a padlock with a high security rating to last more than a minute.
Can't edit the above now, it should read as a maintenance person, not a maintainable person!
DITTO,
Just got myself an Abus granit victory x-plus 68 for the front of the 1200GS and a Pragmassis anti pinch pin and ss65cs padlock for securing the easy to steal rear wheel,, going to get the BMW alarm system installed at first service, I suppose this is as much as I can do to protect ride while having something to eat, or a coffee, because youtube videos show angle grinders destroy everything so, the rest is up to the insurance companies.
I wouldnt bother with the alarm
They are a pain in the arse when they fail which they invariably do and no one takes notice of them any way
If it is just to alert you to a scrote grinding through all the other stuff you have then get an alarmed disc lock and save yourself a fortune in cash and the headaches
And don't forget the pound of butter in the fridge
Cheers for the headsup, I will do that then, so 2 disc locks one with alarm, anti pinch pin, and a pound of butter in the fridge, lmao, still aint figured out what that butter story is, guess im to new to the forum, advice highly appreciated.
Yes, but those days were before Mobile Smartphones and YouTube University. Kids nowadays are smart hackers
But having said that, unless you have the bike keys, ideally you'll need some pretty dumb 'mates' to help you move the bike.
Can't see sophisticated intelligent lock pickers teaming up with dumb mates to steal a bike, unless its proper organised crime.
Again, not really impulsive opportunists are they.
The abloy 362 is a great lock for use with the Almax chain and ABUS WBA 100 ground anchor or the 342 for smaller installations and sheds
