Fellhopper
I have a problem with the starter motor on my 2003 1150GS. The problem began with the starter seemingly failing to engage and turn the engine over. It would still make the fast higher pitched sound which I think is the motor itself running but I am thinking that the gear isn’t being thrown forward by the solenoid? It would do this perhaps once every 10 goes then this increased to nearly every time the starter button was pressed.
I have stripped and rebuilt the starter motor ( see photo - there is some arcing on the plate but all OK ). All magnets present and correct, all lubed and moving freely but the problem persists.
Before I order a new starter motor does anyone have any thoughts? If it is the solenoid switch, presumably this can be bought separately.
