quick and dirty test:
if you short the two M8 terminals together you should spin the starter. that will prove the starter motor itself works.
shorting the live M8 to the small spade terminal should throw out the pinion and turn the starter. that will prove the solenoid and engagement mech works.
use an old pair of pliers for the job.
if it turns out not to be the relay
