Haggishunter
Hi, I need some help with a starting problem on a US spec R1100GS. History of problem is as follows:-
About a month ago, the ABS started not working when starting the bike, but okay if bump started. Suspected low voltage on start was causing problem - however, battery was on optimate charger all the time.
About a week ago, the bike refused to start when I stopped for petrol - very sluggish to turn over and completely flattened electrics, causing RID display to clear, clock to go to 0 etc. After about 10mins of sitting, bike then restarted, but only just.
Got new Hawker battery from Motoworks and fitted this. On pressing the starter button, was expecting nice quick turnover and easy start - instead, still very laboured turnover and only just started! After stopping the bike and trying to start again, very very laboured turn over and then the relay on the starter motor starts clicking like mad - bike will not start at all and electrics are being flattened when the started is pressed.
I have to suspect that the started motor is duff, as it is getting very hot - am I right or can anyone else suggest anything. If it is the starter motor, easy to remove and refit 2nd hand unit or what?
Any help on this greatly appreciated.
Graham
Graham
