Starting
rally100
Wales
Bike is 18 months old with 80 hrs wouldnot start out on the trail when hot so put a new battery on in the week started fine went out today and after 5 or 6 starts battery seemed to die wouln t start on the button. push started ok then :mad:progresively got worse started to miss and splutter 5 miles from home stopped and then wouldn t bump or tow start any ideas
Is your alternator charging? I have a little tester you place across the battery, tells me if its being charged and the condition of the battery.....
I'm first to admit I'm no mechanical expert but has it had its valve clearances checked? I believe if these are out of spec it can cause similar issues to yours?
