Dutchman
If, like me, your underwhelmed by the puny OE horn on most modern BMW bikes, you might like the sound of the new Stebel Nautilus Compact horn, which I've just fitted to my 1200GS with ear-drum shattering results.
This is a 139dB twin tone airhorn which differs from the standard Stebel Nautilus by virtue of the slimmer shorter plastic trumpets which now make it much easier to fit between the forks of most bikes.
I had to fabricate a stout alloy bracket for my particular application, but it can be easily fitted just by removing the offside tank panel of a 1200GS or the tank on the 1100/1150.
Wiring to the GS is straightforward, it works perfectly without the supplied relay and does not conflict with the CanBus system on the 1200.
It comes with okay fitting instructions and for a limited time only are available from us at Motorrad Concepts.
http://www.motorradconcepts.com/specialoffers.htm
Fitting FOC for those who wish to visit us in Edinburgh.
Dutch
Dutch
