Nasty1
Click, Click!
It's not a cure for faults![]()
Why not?
A little bit of background though:
-fuel consumption went up since about four months
-starting the engine not as smooth as it used to be. Engine often cuts out after the first couple of meters (downhill).
-warning light went on last week after TBS. Went out right before the mechanic turned the ignition key (second time it does that).
-idle is unstable (between 1050 and 1300 on a hot engine), 950 on a cold engine. Also the brass screws are completely screwed in so no more play... This wasn't the case last time I did TBS.
have you read about balancing the throttle bodies ?
its obvious that something has been 'adjusted' 4 months ago.
fuel consumption up = rich
engine cuts out = rich
brass screws in = rich
idle unstable=rich
either fix it yourself or get someone competent to do it properly ,
why don't yuo tell us what happened 4 months ago ? was it a dealer or did u do it ?
are you capable of doing TBS - cos if u are u need to do it again.
search for the TBS for BMW twins as a pdf and follow that
read this : http://www.ibmwr.org/r-tech/oilheads/R11Manual/Oilhead_Maintenance_2-25-02.pdf
and this: http://advwisdom.hogranch.com/Wisdom/TBS4Dv1.0.pdf
Speeking of someone competent...Put the spanner down son and step away from the technology...thats it nice and easy...
Dear Mr Steptoe,
I might not be the technical specialist you are, but I am learning everyday. I am the curious type and that has lead me to successes throughout my life. This kind of attitude is not what I expected of a person like you, but I only know you from this forum.
In the meantime I sorted out what the butterflies are. In fact I knew what they were, the only thing was I didn't know they were called butterflies. Sorry, I am not English native but again, I try my best and I am learning every day. Furthermore I speak fluent Dutch, French, English, German and a little English as you might have noticed. If I misunderstood, my apologies.
I know my limits and I am clever enough not to touch any sealed bolts on a delicate engine like this.
The engine warning light, sorry again for my not knowing the correct terminology, is a red light on my dashboard with a white triangle in it. I was told by my dealer that I better get the bike checked if the warning light is on. Which I did this afternoon.
But again, I might not be the specialist you are.
I don't tend to give up that quick. Speak for yourself Mr nice and easy.![]()
FFS
Some of you lot have got no tolerence. The guy only asked a question.
I might have an idea of what the problem is ( maybe two problems) -but seeing as it wasn't the question that was asked, and demito keeps taking one stepforward and twosteps back, getting two dealers involved and then inbetween trying to do things himself and making no end of added problems, then blaming something i suggested, although the bike already had a problem - .
i'll let this one pass .
