Steptoe Spring Service day 16th April 2011
Sgt Bilco
Dream Maker
Moderator
Moderator
Evesham, England
The sun is out and everyone's bike will need a fettle by the expert St Eptoe so he's on his way out of West Laaandaan to the wonderful countryside of Warwickshire:thumb His visa has been approved so it's all systems go for Saturday 16th April 2011 at:
C&D Auto's
Unit 2A, The Halt
Bird Business Park
Long Marston Nr Stratford
Warwickshire CV378RP
As always, all GS's can be accomodated but Neil won't be able to do anything too complicated due to time limitations. Service, check up and tune up by his nibs is what is on offer here. If you want anything else done, let me know and I'll see if it's possible. You will also need to bring a service kit and oil for your steed which can be got from your local dealer or motorworks. This will ensure Neil doesn't have to cart his stoteroom up from the smoke. Please make sure you arrive 1 hour before your stated time as the engine needs to be cold to do the valve check.
Cost will be between Steptoe and yourselves depending on work done (cash only please) and a contribution of £20 for use of the workshop. This goes to the running of a Superstock race team run from the workshop and with any luck, the new Kawasaki ZX10R will be there to have a butchers at:thumb
We can also do tyres if you want a new set of boots fitted. If you let us know and bring them along, Mad Moose will expertly fit and balance them for £10 a wheel which also goes to the race team.
Each service takes around 1 hour including coffee and doughnut time:augie
Please pm me if you want to have your bike done and it's on a strictly first come first served basis.
hi would it be ok just to pop in and have a chat with st eptoe about getting:thumb a clutch change ? and maybe a donut
I'm in Sarge, R1200GS 04 plate, valve and valve end float check, TPS check and throttle bodies balance and general check over. :thumb
If possible please add me to the list thanks.
52 plate R1150GS Valves, throttle bodies set /TPS
Pmmed you
Guys
Here's the order of play for 16th April. Neil will normally be ready to rock and roll at 9.00 and allow 45 mins to an hour for each bike. We'll also need lunch and donut breaks. I haven't put times on because I'm sure you'll be able to work it out. If you ar ehaving valves done, please turn up an hour early to let your engine cool down.
If you are having a full service, please make sure you bring your own oil and filters etc along. Steptoe will have some odds and sods but he won't be carrying loads of bits. You can either get them from your dealer or get a service kit from Motorworks
Mad Moose R1100S Boxer Cup service
Wreck Diver R1200GS Throttle bodies TPS etc
Lord Snooty R1200GS Valves, throttle bodies TPs
Eddie Sears R1150GS service and tune
Dazchallenge R1200GS service, oil change and tune up
Flatdog R1150GS Valves, TPS and throttle bodies
Shapeshifter R1150GS Throttle bodies
JPR R1200GS TPS throttle bodies and service
Rasher R1200GS FD oil change
Grim rider R1100GS
Sgt Bilco F650GS service and tune up
All are welcome to come along for a coffee and blether:thumb
Nice one Chris, well done for organising the necessary visa and complex travel arrangements to enable St Eptoe to travel north of Watford Gap! :D
I'd like to add to this a check of my gearlever as it is sticking now and then making it difficult to change down.
That will be the linkage. Had the same on mine last year and teh ball sockets had seized. Took it apart and used liberal amount s of copperslip and it worked wonders:thumb
