Steptoes west mids service day 9th june 2012
mad moose
Evesham Worcestershire
The sun is out and everyone's bike will need a fettle by the expert St Eptoe so he's on his way out of West Laaandaan to the wonderful countryside of Warwickshire His visa has been approved so it's all systems go for Saturday 9th june 2012 at
C&D Auto's
Bickmarsh Lodge
Ullington
Nr Evesham
Worcestershire
WR118QJ
It's a concrete road off the main road and C&D's builing is at the end of the farm on the right. If you get to Bickmarsh airfield you are very close.
As always, all GS's can be accomodated but Neil won't be able to do anything too complicated due to time limitations. Service, check up and tune up by his nibs is what is on offer here. If you want anything else done, let me know and I'll see if it's possible. You will also need to bring a service kit and oil for your steed which can be got from your local dealer or motorworks. This will ensure Neil doesn't have to cart his storeroom up from the smoke. Please make sure you arrive 1 hour before your stated time as the engine needs to be cold to do the valve check.
Cost will be between Steptoe and yourselves depending on work done (cash only please) and a contribution of £20 for use of the workshop. This goes toward the running of a British Superstock 1000 race team (JDR Racing number 86) run from the workshop and with any luck, the new Kawasaki ZX10R in full race trim will be there to have a butchers at.
Each service takes around 1 hour including coffee and doughnut time
Please pm me if you want to have your bike done and it's on a strictly first come first served basis.
The running order is:
9.00 DarronPtalbot Valves TB balance and check
10.00 Grimrider Valves TB balance and check
11.00 Rasher check over and clear down ECU codes
12.00 Ed Sears Valves TB balance and check
13.00 Dom Valves TB balance and check
14.00 Brian O SERVICE AND TUNE UP
15.00 Spotster Valves TB balance and check
16.00 Mad Moose Valves TB balance and check
My contact number if needed is 07824380691. Please remember to bring all parts with you as Steptoe will not be bringing his stock room with him
Good timing Moose, please pencil me in for that. I will have to let you know a bit closer to the time to confirm my place when I know whats going on with my treatment.
Steptoe did a fantastic job last time and I would hate to miss the chance of the Guru being in town :thumb
Cheers mate: :beerjug:
And what bit of your bike are you going to take then:augie
Thanks again to Steptoe for accommodating me at short notice. If only I knew he existed earlier I would have saved a packet in servicing and Vines in a load of coffee waiting! Thanks Neil
Probably really stupid question, but quite new to this so you will just have to excuse me - my bike is due a service in Jun / July - was planning on the local dealer ( Gloucester), but from the sound of it will have a much better job done here. Will this suffice for the service (obviously without the stamp in the book) and if so what is likely to be the cost. Also, any issues with watching the work being done as keen to learn.
you will have a better job done with neil the cost will be less than bmw and you will be able to watch the master at work pm me to book your space
Don't forget to bring your own oils, filters and plugs etc.
I can bring brake pads if you need any. Let me know in advance.
i will put my boxercup replica at the entrance to the yard so you all know you have the right place there is tea, coffee feel free to bring donuts cakes etc
