Aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaah
out yesterday in the hot weather and here we go AGAIN !!!!
so it will be fine for a little bit but when all warned up, you can change up through the box but will literally refuse to change back down.
Normally if you're off the throttle for a bit in said gear like 5th or 4th and just wont change down ????
new slave new master pretty sure bled properly! had no trouble on 1000mile run but was cold as hell !
It's like the pressure plate is done or something as clutch doesn't slip ? dry rusty splines ?
How can i inspect the clutch without splitting bike or is it unlucky chucky get on with it .
Cheers Duncan
