Sticky piston
Santa-2512
Omnipotent one
North Pole
So following on from my rough running,
I noticed that the bike would occasionally slow as though it was pulling shit through the injectors,
keeping a WOT it would cleqr and normal running was resumed
Then a couple of days ago, i though I had a flat , the bike was very hard to push, but once rolling , normal service was resumed
I'd run some fule stabiliser into the tank, so i was confident it wasnt that
Anyway comming home tonight at about 50mph, i tapped the brakes to bleed off some speed for slowing traffic
And it kept slowing and slowing, i needed more throttle to stop the bike from stalling, going down through the gears
and as fast as it started it stopped, and i carried on as normal
Brakes was my first thought, and when i got home i went checking
Rear disc, cool as a cucumber , so not that
Front right disc again cool
Front Left disc , hot .. Stoppie hot !!!!!!
and there is a slight hue to the disc , not blued, but it has a slight colour
So the strip down commenced
The pads pin , was sticky and is showing early signs of wear, so I'll replace them both
The pads came out with a bit of wiggling , lots of caked brake dust but in reasonable condition
The wear bars are still evident on the pads, so there not worn out, but the LH pad has a strange mark on the contact face , might be nothing, bot worth noting
The two inboard pistons went back in very easily, the two outboard pistons are hard to get back in
I used the old pads as spacers and pumped the inboard pistons back and forth , there free and I'm happy with those
The outboard pistons are what is troubling me , I've managed to free the lower piston, Leverage & brake cleaner , and it goes back in with a lot of pressure
The upper piston needs a lot of pressure to get it moving back in from extended, but after a certain point moves a bit easier,
They don't look scored or stuck they just don't like to move
I turned the pads round and dropped the mounting face onto the piston, and pumped it, to simulate a metal to metal contact and then sprayed the piston with brake cleaner
Again its a pita to get moving and back in
Any ideas, or is it new calliper time ?
Might be the inner seals have gone, and muck has gotten in between the piston and caliper wall.
Buy yourself a used caliper to swop over so you can strip the sticky one and rebuild it, after deep cleaning
and new pads
Motorworks have used calipers, for £100.00 handy spares.
I have done this a few times on different bikes over the years, so I can keep riding. Good luck.
I would get it rebuilt professionally by a specialists, I think “powerhouse” was a company name.
FWIW a mate just came off his Speed Triple on the A3 at high speed last week and he thinks it was due to a jammed piston. He was lucky not to have hit the Armco at speed or get run over.
Edit: trading under a new name…..
In my experience it’s the expansion of corroded bare alloy in the piston outer dust seal groove that grips the pistons and causes sticking, requiring a full calipers strip and rebuild with fresh seals.
If you rebuild the calipers yourself, I believe the recommendation is to not split the caliper halves. Doing so is likely lead to leaks after reassembly. Seal kits don't even include the little o ring that goes between the caliper halves.
So i popped the pistons back and worked them a few times , seems ok
Fitted new pads, and all seems good on a the test ride,
Ill keep and eye on it , if not its £300 for a new caliper , and then the mad scramble for someone to fit it before i go away lol
Dont think its all good at mill :(
When i got to work this morning , LH disc hot , Rh disc cold
Summat is not right
rather than faff around with refurb kits , i may just bite the bullet and order a set of calipers , at least i know ill get another 15 years out of them
I did the same although mine were only beginning to get a bit sticky. Bought a pair off here for 90 quid and will refurb the originals so will have them ready for the future.
its corrosion behind the dust seal and the brake piston seal - clean it up with a dremel
the dealer's stock (or should), new pistons and seals in a rebuild kit (4 pistons and 8 seals per kit)
if the pistons are not stone chipped or corroded - you can pull it apart without fitting anything new - but its a little naughty - but remember the mess you are riding with now - is the very same stuff - just stuck with rotting seal grooves !
So i rang my mechanic today,
he said unless i can get the callipers for virtually FOC, don't bother, he will strip flush and clean / grease everything up
so booked in for week after next :)
Only just seen your post. After you mentioned the LH disc was hot, I was thinking seals. Maybe new pistons if they've been scored. But it's a relatively straightforward job, especially if they're still moving in and out!!
Maybe fit new pistons as well?
I'll let you know. What the menders say ;)
It's booked in for next week
