Still new here..
Joe narvey
UK
Where's the best place to get an additional aux power socket fitted preferably the jump start version .
In in London SE1 area.
Before you leap to your keyboard and say read the sticky, you're an idiot or its simple what's wrong with you,etc etc I'm not interested unless you name a reliable person that can fit a slot that doesn't blow things up and can be used for a jump start if need be.
Also... best tyre to fit for predominately road use?
Best Tyres by a long way are michelin PR4 Trail
Cant help you with your other issue
Many thanks. I may have a puncture, tread isn't too low but I have a trip coking up so may swap. Thank you.
Thanks. I bought the jump start socket and am aware delivery of the croc clips that plug into the socket. I'm assuming the cables go straight tt he battery and not fused ?
The additonal socket I want is a standard (non-din) socket for accessories as opposed ot using an adapter. I assuming this would need ot be wired via a relay and fuse box. Thsi is where I'm reluctant to start pulling things apart !
Will contact 'Mikeboy' Thanks for the advice.
If you are looking for an additional jumpstart terminal rather than the plug in charger type then.
Scroll down this page a bit
http://www.motorworks.co.uk/vlive/Shop/Parts.php?T=5&NU=15&M=30&Ct=IA&SbCt=BA_15_30_IA_10
You don't mention bike type but this should help you
If you want someone to fit it then Steptoe or Mikeyboy may be able to help.
Though it's a piece of piss to do yourself.
