Will have a look after doing comp test. Thanks
hall sensors??
When you swapped the plug leads over, did you swap them over at the coil as well as the spark plug, because there is no need to. The coil fires both plugs together at the same time.
Leave the coil end alone, and just swap the leads over at the spark plug end. See if the fault transfers, you may have a faulty coil.
Ian
PS
It's easier to leave the spark plug ends alone, and just swap the leads at the coil. Does the same thing.
you have an ignition problem on the right cylinder.
It has sufficient compression,and it has fuel according to your trouble shooting thus far.
could be that HT wire is bad/weak, that spark plug, or that ignition coil terminal.
Also loosened the tps mounting screws to see if that altered anything. It made a noticeable difference so I assume the tps is doing something at least.
Any more ideas appreciated .... thanks
Stop chasing your own tail
Do a search on here or elsewhere and set the tps properly, if all looks good then you can eliminate it!
Reading back through your posts, this does appear to be a conundrum.
Are you sure your valve clearances are correct and that you made the adjustments correctly with the piston at the top of it's stroke, both the valves closed and the rockers loose.
If you had to make large adjustments, particularly on the side that is giving you a problem, then that might point to your problem.
Probably clutching at straws here, but think back over what you did during the service, large adjustments anywhere may point you towards your problem.
Ian
Check the resistance across the terminals on the fuel injector. They should be very similar, if there's a difference that could well be your problem.
