Stinking Wet Motocross Boots
Warlord
Walsall, West Midlands
Ok, so I'm new to this stinking wet motocross boots malarkey
Once home from Green Lane riding, covered in mud, and wet motocross boots
A) How do you dry these motocross boot things out, especially in Winter months?
B) How do you stop them stinking the house out, and keep the wife happy?
Tips, Tricks and methods please :thumb
Clean them asap, preferably when dirty
Pressure washer is good
Stick them in an airy garage
I hang them upside down, on 2 brooms in the garage
Mine never stink and last for years
Abuse will ruin them
I got fed up of the stinky smell today, and rinced them out with clean water (inside and out).
Removed the foot liner
Scrubbed them down with Fairy Washing Up liquid as it has anti-bacterial benefits, inside and out.
Hung them upside down in the sunshine for a bit, to dry out in the Autumn Sun.
:confused:
Ditto
As for keeping the wife happy Warload, well, if you don't know by now she ain't gonna be hanging around for long.........
Andres
Cheers.
Don't have a pressure washer that's easy to get to. It's buried in one of the sheds.
But can hose it down, with a brush. Seemed to clean them ok.
I'll go buy a couple of broom handles to hang them on indoors.
Ditto
Andres
She's hung around long enough and right up until these feckin stinky boots were located in the house, by her nose-radar
Hose clean. Rinse in Very very weak domestos solution. Dry slowly then cook in direct sunshine if and when you can. UV light is good at killing off bugs.
+1 ......I also spray my Sidi Crossfire boots with GT85 which helps to keep the metal components on mine 'corrosion :D' free
You might try putting screwed up newspapers inside the boots to wick the moisture away too.As for smell after they are washed and dried spray some aerosol based foot power inside to kill any germs.
You might try putting screwed up newspapers inside the boots to wick the moisture away too..
Yep ... might seem old fashioned but it works every time .....
It's the basic things in life .... :D
Shhh... she hasn't seen them in the guest room en-suite yet, radiator in there seems like a good dryer :eek: :thumb
What about scrumped up Microfiber cloths. Got loads of those, but don't read newspapers
Screwed up newspaper definitely soaks up plenty of moisture.....
Yep, stuff with screwed up newspapers and leave in the airing cupboard- the ambient warmth dries them nicely but not too aggessively.
Tights full of cat litter or silica gel works, so I'm told.
I'm sure I've seen a photo of you with your trousers inside your boots, you need them outside, some folk tape them round or put a band of old innertube round in the hope of stopping ingress.
Yep he is wearing them wrong
Trousers over boots for trails
So your suggesting he pinches the misses tights now as well as ruining her guest Bathroom.........:rob
On road, all the wet weather gear I wear trousers on outside.
However, being as though water was so deep in places it covered my boots anyway. Doesn't matter if trousers are outside or inside as far as my day went.
Water still filled my boots.
The kit I'm wearing is very old and torn around the leg (from a crash years ago) so it served better tucked away that day.
