Hello,
Sorry to bore you with yet another servo/ABS problem but I have spent hours going through the forum and cant find another quite like this.
I have a 2005 GS Adventure with Servo/ABS brakes.
All has been working fine till the wheel was off for a tyre change last week.
Now it doesn’t work fine…..
I’ve had the wheel off, calliper off, checked/cleaned everything twice now since but still have the same problem.
I’ll detail the symptoms and hopefully one of you gurus will be able to give me some advice, other than do away with the servo/abs…..
Ignition on, servo screams but doesn’t reset, just keeps going.
ABS light flashes fast and the general warning triangle light below it stays on.
Front brakes work fine, rear has no power (servo off?)
Ignition on while holding down the ABS button to switch ABS off, servo sounds and resets as would be expected.
ABS light stays on, general warning light switches off after a couple of seconds.
Front and rear brakes work fine, servos work as expected, ie, rear works from rear brake, front and rear work from front brake.
This is exactly what I would expect to happen if I started the bike while over riding the ABS.
If I disconnect the rear ABS sensor and turn on the ignition the ABS light flashes slowly as I would expect but the general warning light stays on.
Sounds like an ABS problem then?
To confuse even further, sometimes, when I’ve forgotten to hold the ABS over ride button down the servo and ABS start as normal and work fine. ie ABS light flashes slowly, general warning light goes out after a couple of seconds, ABS light goes off once I start to move, then ABS and brakes work perfectly.
Do I have a duff ABS sensor? Is there any way to check other than forking out for a new one?
HEEEELLLLP……. Please?
