alp
I like to make subtle mods to my bikes to personalise them. Here are mine so far:-
a) Screen displays Miles to Empty in the top line....I was checking this today and took it down to 20 miles left before filling up. I now have confidence in this read out. Anyone taken it closer to empty yet?
b) Screen displays MPH in numbers in the bottom line.... I no longer look at the analogue speedo. Highly recommended.
c) Rubber bungs fitted in all the open frame tube holes.... I made these up myself and it really tidies up the side view. A non BMW dealer remarked how it adds to the quality appearance.
d) Raised the gear change lever....The lever is easily adjustable for height position. I raised mine to give a bit more room to get my boot under the lever for upward changes. You just need a 10mm spanner to loosen the 2 locknuts and an 8mm spanner to rotate the threaded link.
e) Screws (6mm and 8mm) fitted in open threaded holes in lower part of the engine casing.... These holes are for the engine bars but if the bars aren't fitted the screws will prevent road junk getting into these threads and prevent problems if fitting engine bars at some later date.
(Sorry no photos)
(Sorry no photos)
I'm waiting for a crud catcher from Mr Hooton, and a fender extender whenever they get round to making one.
