Sump guard anti vibration mounts
Rugged Path
The Honourable.
Wybunbury, Cheshire East, England, EU
From the photo, the threaded bolt section has come apart from the rubber (front bobbins). I did try previously to repair it with a strong glue but, it failed on tightening.
Roughly a tenner for a BMW one which is 25x15 M6.
Flea bay sells 20x15 M6 as a pack of four for £6.
So going for the latter unless anyone knows a vendor that sells the OEM size.
Patria o Muerte
clean out the threads in the casing , i put a washer between , only do them up finger tight , to make them easier to remove next time.
On the photo, the part missing was the (glued) attached disc with an M6 threaded shank. That section on the 02 1150GSA is bolted to a small bracket and not into the casing.
Patria o Muerte
I’ve got the same problem on one of the mounts on my bike and I was wondering how to fix it so I’ll be watching this with interest.
I have just ordered a 4 pk of the 20x15 size bobbins for the sump mounts instead of one OEM sized item.
Only the 15mm height is relevant.
Including free postage.
In fact anything to use as a 15mm spacer would suffice.
Patria o Muerte
I have just ordered 20x15 sized bobbins which will work just as good from another seller.
For the perfectionists out there who want the same size as the OEM, I found this seller.
Patria o Muerte
