Suspension tuning and service recommendation - Bristol/SW
Green Boy
hampshire
Hi all,
Just wanted to pass on a contact for suspension tuning and servicing in Bristol. I've got a '13 1190 Adv R and felt the fork set up wasn't right. However numerous phone calls drew a blank as no one appeared to want to touch anything larger that MX bike forks, within a couple of hours drive from me. Ending up finding Mitch of Technical Solution who runs his own business in Bristol, has a spotless workshop and helped interpret my ramblings into something coherent and worked out that the spring rate was correct but the valving was very soft. He solved this as well as changing the seals etc. In summary very pleased:
http://www.technical-solution.co.uk/index.html
NB: I'm nothing to do with Mitch or his company, just a happy punter! :thumb2
By way of a review after 5 months of usage both on and off tarmac, Mitch's work on the forks made a massive improvement to my Adv R and so he's just serviced the rear shock and discovered a similar shim situation in this. Basically it was very soft at the beginning and end of the stroke and firm in the middle. Now this has been corrected, I look forward to fitting it and 'feeling' the results.
Once again he was a great guy to deal with, turned the job round quickly and his procing was very fair.
:thumb
