Sold SW Motech Pro tank ring for BMWs without screws on filler cap
Issuds
Member
Lincolnshire
I am selling a used tank ring for BMW bikes without surface screws on the filler cap. This is taken from the website.​
£35 posted to UK.​
PRO TANK RING​
For this PRO tank ring model, the factory-installed tank filler is replaced by a tank ring adapter. The PRO tank ring is attached to the tank ring adapter.
The QUICK-LOCK locking mechanism of the SW-MOTECH tank rings, which has been tried and tested for many years, can now be operated even more easily thanks to the magnetic guidance aid from Fidlock technology. The positioning of the top ring has been significantly improved: the sliding top ring comes already pre-assembled on the tank bag with a guide rail, and the tank bag does not need to be drilled.
This way, the top ring can be custom-aligned onto the guide rail on the underside of the tank bag. Once the right position has been found, the top ring is screwed tight. When changing to another motorcycle, the position of the upper ring can be adjusted accordingly.
