it's not as if the OEM bmw valves have an untarnished reputation for reliability.
I had the first of my valves in 1998 for racing, and I put them into a r100rt test engine that was used on the motorway 5 days a week, I inspect them every year, he has now covered 60000 miles on them, and they are still very good,they also stand 10000rpm in my race engines, and flow more air. they are one piece 214n stainless forgings with a plasma nitride coating and stellite inserted into the tip. they are also lighter than a standard valve. I will still fit bmw valves if people bring them to me but not swiss int I just dont want the comebacks.
the racing sidecar engine had them in when he gave it to me, he had over revved it by his own admission but only to 9000 and the head came off one of the valves punched a hole through a piston, got cought on top of the conrod and came out through the top of the crankcase. jim cray can also tell a few stories thats why we dont use them.
Thanks Richie......this is the kind of info i was looking for... an opinion backed up with hard evidence.
This thread might seem a bit like that Rob but was just trying to make an informed decision based on hard evidence rather than just heresay.The current wisdom on valves is that Swiss Intervalves are the best available at the moment for road engines, the OEM valves are made in the States and the last batch supplied did not have the stellite tops to stop them wearing where they come in contact with the rockers, the manufacturers could not confirm whether they were going to make any more with hardened tops, without the stellite tops they are fine for water cooled engines, but not for air cooled.
A cautionary note on Intervalves.............there are some that have not had the ground finish on the stems, these have lathe tool marks going round the stem instead of the matt finish when ground, the unground ones tend to wear the valve guides prematurely, (under 10,000 miles) and so should be checked before fitting, if they unground they need to be changed.
There are also some one piece valves available, fine for race engines that are unlikely to do more than 1000 miles between rebuilds, good tough valves but the machining for the collets prevents the valves rotating in the collets and keeping the seats clean.
