Going to be adding a centech ap1 fuse panel but wanted to have the ability to choose between 'always on' and 'ignition switched' power, a facility built in to the more expensive centech AP2 and the 'fuzeblock' product. Im not sure yet what I would need to power with ignition off but i would rather have the option than not if the need arises.
I have come up with the following, using a switch fitted to a cutout in the fuse box, which can be reached from the side without removing anything from the bike. The feed for the relay will be switchable using 'add a circuit' piggy back fuse inserts from F3 (always hot) and F7 (ignition switched).
Im not very experienced with auto electrics so is there anything im not considering?
Gordon
Gordon
