swopping rear shock
  • Thread starter Thread starter jennabusa
jennabusa
does anyone know if the xchallenge rear shock will fit the xcountry.? i,m thinking hyperpro , my rear shock is set at 335mm centres at the moment, is that similar to the xchallenge ?.
The difference between the wilbers which is specific to the xcountry and hyperpro who only make one for the xchallenge is £70 i,m sure they are both as good as each other.
Terry
the Challenge has more wheel clearance and suspension travel than the country. They are not the same length as far as I recall. If you fit an challenge sized shock it will raise the bike a little
