Garry H Well-known member UKGSer Subscriber Joined May 16, 2002 Messages 1,297 Reaction score 68 Location Midlands Mar 29, 2026 #1 My take on a protector to keep the crap off the rear shock Still a bit more tweaking but i recon it will do the trick nicely
nicholsonj2252 Well-known member UKGSer Subscriber Joined Oct 19, 2014 Messages 1,992 Reaction score 1,450 Location County Durham Apr 14, 2026 #2 I've fitted a BMW OEM shock guard off an F900GS Part number is 33 4 8 359 968 and it cost £12 It fits with two plastic rivets ( 51 11 1 908 077) so easy to remove if required
JDS Registered user Joined Nov 12, 2023 Messages 36 Reaction score 16 Location Manchester Apr 15, 2026 #3 nicholsonj2252 said: I've fitted a BMW OEM shock guard off an F900GS Part number is 33 4 8 359 968 and it cost £12 It fits with two plastic rivets ( 51 11 1 908 077) so easy to remove if required View attachment 495427View attachment 495428 Click to expand... could you please say where you purchased the part from. I can't find it on any parts sites? many thanks
MrC99 Well-known member UKGSer Subscriber Joined Aug 16, 2015 Messages 1,354 Reaction score 963 Location Honiton 🇬🇧 or Chinon 🇨🇵 Apr 15, 2026 #4 This part on RealOEM ? Part number is 33548359968 (there's a 5 missing in @nicholsonj2252 's part no.). BMW dealer should be able to help.
JDS Registered user Joined Nov 12, 2023 Messages 36 Reaction score 16 Location Manchester Apr 15, 2026 #5 MrC99 said: This part on RealOEM ? Part number is 33548359968 (there's a 5 missing in @nicholsonj2252 's part no.). BMW dealer should be able to help. Click to expand... thank you
pistonlegs Registered user Joined Jun 8, 2026 Messages 4 Reaction score 0 Location London Jun 8, 2026 #6 MrC99 said: This part on RealOEM ? Part number is 33548359968 (there's a 5 missing in @nicholsonj2252 's part no.). BMW dealer should be able to help. Click to expand... Did you have to drill holes to fit? has the protector rub into the tyre in any ocassion? Thanks in advance.
nicholsonj2252 Well-known member UKGSer Subscriber Joined Oct 19, 2014 Messages 1,992 Reaction score 1,450 Location County Durham Jun 10, 2026 #7 pistonlegs said: Did you have to drill holes to fit? has the protector rub into the tyre in any ocassion? Thanks in advance. Click to expand... Yes had to drill two holes for the plastic push fit rivets to go into . The protector has not rubbed the tyre at all Sent from my iPhone using Tapatalk
pistonlegs Registered user Joined Jun 8, 2026 Messages 4 Reaction score 0 Location London Jun 10, 2026 #8 nicholsonj2252 said: Yes had to drill two holes for the plastic push fit rivets to go into . The protector has not rubbed the tyre at all Sent from my iPhone using Tapatalk Click to expand... Cheers. Much appreciated. Useful info. Will do the same.
