t/shock d/shaft oil level?
cringe
stoke staffs
Have a 1981 R65 Twinshock. Have done as Haynes manual says,drain oil from shaft, put 150cc in(shows 2mm on inserted rod) ,take for run to warm up .Then put rod in filler hole again on top of shaft and oil should be 2mm up rod,but it is way below shaft top .Is this correct way ?.Have drained/filled/run several times but level below shaft still .
