Oil level in d/shaft twin shock
cringe
stoke staffs
I know it seems a stupid question,but how do you check you have the correct amount of oil in the d/shaft on a 1981 R65? In the book it states draining and refilling with 150cc ,then inserting a rod through filler on to shaft ,it should show oil on rod 2mm,but does not show with extra 20 mm put in !
I pressume the bike is on level ground and the rod is on the shaft and not gone past it.
oil level in drive shaft
Yes bike level and rod on top of shaft,does it do any harm too much oil in d/shaft?
