T.T brackets
davegs
bromley
I have a 660 on the bike to return home from the Stafford do, however, during the rally I was forced to consume a great amount of Prof's cider. Getting home in a bad way I've forgotten how to take the gps off!!. so can somone PM me to tell which bit I press to release same. Many thanks, Dave GS
lockable or non lockable
if its lockable you need to use the key which then just allows the top bracket to open, press the little black stub on the RHS and she will pop forward.
Many thanks for your reply, trouble is it dosent pop up when key is turned!!, guess some things got stuck, will have a serious look today.
Sitting on bike, insert key with left hand. It won't turn at this point. With right hand push little spring loaded tab on right side. As you do this turn key anti-clockwise with left hand. Clamp will lift. Then pop the little black plastic tab on the Garmin cradle.:beerjug:
