I removed the side Vario mounts with no problems and properly covered the loose cable ends with rubber blanks. The tail did not overly sag during this as I properly secured it to not fall more than enough to get my hand in. Since doing so I am hearing an electrical buzz coming out of where the radar plate is or one of the tail lights not sure. Bike is functioning normally. I separated the ends from each other and also tried using electrical tape instead but no change.
I want to reiterate that at no point did anything get pulled on, supporting itself via the cables or pinched.
