nozza
Recomendations for a tankbag to fit 1200gs please
Nozza
Nozza
Wots up !! thats what I'm asking, are they any good, are they over priced, is there a cheaper n better alt thats the gist
E-bay....... never used it
Nozza
Nozza
Do a search on this site, under the 1200 section.
Several threads on the topic.
IMHO one of the TT bags is best, the BuMW being:
Too big.
Too expensive.
The map pocket doesn't take A4.
Awkward to use.
No need to say more.
The Touratech 055-1132 has my vote easy to put on and take off its waterproof and comes with a A4 detachable map pocket if you need it and it really does look the dogs bollocks.£177 but worth every penny.
Tommo, I agree, the Touratech 055-1132 does look the dogs, which is why I ordered one, but I've just sent it back. It's got a loose waterproof liner inside which, if you put all your stuff in there, makes it into a 'waterproof tankbag'. It looks to be much the same as the Touratech 055-1124, which has a slightly reduced capacity but doesn't rip you off to the sum of £71 for a 'plastic bag' to make it waterproof... you have to find your own plastic bag
The BMW one, which I've had for the last 2 years, is totally waterproof without having to muck about with separate 'bin liners'.
If I were buying a new tankbag now, I would go for the mk2 BMW one. I think that most of the drawbacks have now been resolved... it is expandable, so it's normally not 'huge' unless you want it to be. It now has a map pocket that will take A4, which is also fully waterproof, whereas the Touratech one is not... having only Velcro at the closure, which does not prevent water seeping through. I had to take off the cross-brace on my new 1200GSA because the BMW bag fouled it, which was the reason I ordered a Touratech bag... the trouble is, that one fouls it too.
The biggest advantage that the Touratech bag has over the BMW bag is the mounting system, I wish BMW could have adopted that... then we could have the best of both worlds![]()
Gday
I have the new tank bag on order, the smaller redesigned bag for the adventure1200. I have a couple of questions
Am I reading this correctly does the new bag still foul on the crossbar and secondly, how waterproof is the new bag 50% 80% 100%???
Thanks in advance for the feedback.
Until we talk continue to enjoy........... many great rides.............
i don't think so
savagio,
Whether the mk2 bag fouls the crossbar or not will depend on which Adventure you've got... the later Adventures (mine's an '07) have the crossbar mounted higher and wider on the handlebar, which means that they will foul, although not nearly as much as the mk1 tankbag. I have a friend with an early '06 Adventure and a mk1 tankbag and he has no problems. The mk1 tankbags have a distinct 'bulge' at the front, which caused the fouling on the '07 Adventure crossbar... the mk2 tankbag has lost much of the 'bulge' and therefore fits better.
The mk1 BMW tankbag is TOTALLY waterproof, including the map pocket... I can confirm this after 2 years and 30,000 miles of experience![]()
Anyway, I didn't think it rained in Oz.![]()
