Tank swop
sweetcorne
South Wales
Can I do a straight swop for a tank off my 2088 ( fuel strip) for a 2005 float tank. Is it a plug and play ▶️
the very early low spec bikes (with no brain to do any maths) came with a different pump with a special float - this is NOT the float or pump that came on bikes in 2009/2010
bikes with the trip computer got a ZFE Basic HIGH or a ZFE High - I believe a 2005 float machine got a ZFE Basic Basic, so its possible the programming on the cluster and inside its old ZFE is different, the pump different and thus its float logic incompatible with a normal bike
go on parts thing and spend days cross reffing parts and checking drawings - then give up and buy the Argentinian grown up strip replacement
Thanks for the prompt reply. So whats this Argentinian grown up strip then please
I have a 2007 GSA, with the usual broken fuel strip.
Years ago I replaced the strip with a float from a 2009/10 bike. It clicks on (at least on the Adv pump assembly) but had to use Hank's converter to convert the signal to the bike's ECU.
I'm in the process of reverting all as I bought the new (apparently less prone to failure) strip.
