brokenbarrel1
95 1100GS - ( single cable crossover)Seems when ever I sync my throttle bodies there is always a spot that does seem quite right.(vibration) When I'm riding and at 3600 rpm to about 4000 rpm it will feel off a little bit and not quite so smooth go over 4000 rpm and smooths right out. I can adjust it a little bit and I will be smooth through 3000 t0 4000 but then get a little vibration. Basically it seems if riding at 65mph (not sure how many kilometers that is) the difference would be riding in 4th gear or 5th gear to stay without vibration at the same speed. Does anyone else have this issue. Ive checked for vacuum leaks and all seems good. Just cant seem to get it perfect all the way through the rpm range.The bike has a O2 sensor and I have checked my tps,replaced my O2,new hall switch, cleaned the inside bores of throttle bodies. This is my first 1100 gs is this just the characteristics of the bike and I'm being to picky. Any opinions appreciated. thanks, John
