I'm facing the prospect of replacing my 1150GS ball joint too.
Is it okay to apply the high torque to tighten the ball joint with the the fork bridge in-situ? Is there a danger of damaging steering stops or bending something? Same concern with loosening also. Did you guys remove the bridge and do the job on a bench?
Another queston: My torque wrench range only goes to 140Nm. Can I avoid buying another one that will be rarely, if ever, used again. Would 140Nm plus "bloody tight" plus Locktite 2701 be adequate?
Thanks.
Thanks.
