StevieD
Just cleaning the RS this morning and thought when moving it that it felt a little odd. Checked the front end and found that the lower shock mounting bracket had come away from the wishbone
Anyone had any experience of this and know what the likely cause may have been? Looking at the wishbone it seems the bracket may originally have been attached by a spot weld - If this is the case can the bracket be re-welded or is it going to be a new part?
PS - Bike is a '95 R1100RS with 29k on the clock. Recently found the lower shock mounting bolt was only finger tight, re-torqued it and it was loose again within a month. Re-tightened again and now the mount's broken within the space of a fortnight
Hope someone can shed some light on this.
