charlie bimmerman
Just spent a few hours cursing my ineptitude cos I couldn't fit the Nippy Normans hugger to my 1200GSA. Now I'm not a great mechanic but I can bolt stuff on, take stuff off and generally do light chores on the bike. I understood the instructions perfectly but was stumped by a 25mm hex screw.
It's like this - you first have to unbolt the plastic cover that protects the rear brake hose running along the swing/torque arm. This is attached by two 25 mm hex bolts. Got the first one off no problem. Second one - no chance. Could I get my Allen key between the screw head and the wheel rim? Er no.....not in a million years.
After fannying around loosening things that should probably not be loosened to try and get to the screw head I concluded that the only way to do it would be to remove the rear wheel. Which struck me as a) ridiculous and b) unwise cos I haven't a big enough wrench to undo the bolts and c) I've never taken a rear wheel off a GS before..
Can anyone help on this??? It's driving me nuts!!!
so will ask for help then...
