The Scotoiler
  • Thread starter Thread starter renagade
renagade
I have decided rather than strip me 650 gs down to fit the vacume take off I will open and close the Scotoiler manualy. Good Idea dont you think ????
All I have to do now is think of a way I can lift the plunger inside manualy. The regulator should still work as intended .
renagade
Idiot, just use a spray can if you are too lazy to do it properly. Graham
fitted dozens with no probs drill a small hole in the intake rubber and push through the brass contector with super glue and pliers then nip up with bolt and washer and more glue job done no need to take carb , rubber off.
