The tightest oil filter in the world - EVER. I'm keeping this filter for posterity.
MotoRevive
Wirral, England
I did a mobile service on a clean low mileage 1250GS today. The bike was last serviced at Bowker Motorrad last year.
I slid my Genuine BMW tool over the filter as I've done a million times and it just span..... No grip. hmmmm.
I had a closer look at it seems the filter had been almost rounded off. UH OH ...
A good trick is to place sheets of paper over the filter then knock the filter tool over. It takes up the slack.. After multiple attempts I finally got the filter tool to hold firm. But this filter was TIGHT... I swapped the short 3/8 ratchet for a longer one. Then a 1/2 ratchet. Then finally I had to get out the 2ft breaker bar... Yes. For an oil filter.
The customer had to hold the bike still as I bounced on the filter tool with a 2ft long breaker bar. I almost pulled this fully loaded GSA off it's stand.
Take a look at this filter... The seal is flattened. And almost cut to pieces with the force.
The outer case of the filter is warped outwards with the insane force it was put onto the engine with. I think this is the tightest filter I've ever found on a bike in the last 25 years.
I would guess through experience that this filter was put on with a force of over 200NM. We are talking a high powered 1/2 rattle gun or an ape of a man with a huge ratchet handle. WHY ??? It seems like it was done with intentional malice.
At a main dealer.... Centers of technical excellence... They are not.....
It was a miracle the threads on the engine weren't damaged.
No had tight plus 90 deg turn there ..?
I had to bang a screwdriver into one as the filter was so tight!
So it was nipped up lol
That's the trouble with these amateurs, lol
Never experienced the power of the Friday bike :(
All joking aside, why on God's name do people see the need to tighten something to almost destruction,
You see no thread lock so it might undo
Or someone added a zero onto the torque wrench setting lol
I've a similar issue with the filter on my Kawasaki. I've not been able to remove it. So I've just changed the oil and kicked the filter issue down the road.
I tried using my usual filter removal tool over the end but it spun. Tried my strap wrench but it's just starting to crush the filter. Sandpaper around the filter, removal tool banged on, great grip but not budging. I'm afraid it would just twist the casing and rip it off at filter base then bike would be unrideable
It was me that put it on. I've done all the services on my bikes and just installed it the usual way. I'm paranoid about situations like this so never overtighten.
I think this problem has been caused by the fact it's 4 years since filter was changed and it's "welded" itself on.
There's a local bike shop,non dealership, who work a lot on "problem" bikes . I'm hoping they'll have a solution.🙏
I’ve experienced near impossibly tight filters on two occasions, one on a hard to get at triumph Thruxton and one on an easy to access f800gs. Both bikes were stone cold. I’m sure this wasn’t the case for MotoRevie as he would know not to try to remove a filter from a cold engine. I mentioned it merely as examples of a time saving shortcut that doesn’t pay off.
My other comment about oil filters is that the number of flats on the filter for the wrench to grip means that like an old threepenny bit, it’s nearly round and doesn’t take much slippage to completely round off.
Alan R
I've had this with a bike I've serviced , so i know it wasn't too tight .
a Cali 14 , had to remove exhaust , lower frame rails , footrest plates , cos the sump is too big to just fall through the frame .
destroyed the filter , took the plate off with a chisel!
Little known fact. Archimedes was a bike mechanic in his spare time.
"Give me a lever long enough... "
So I've looked into this.... yea i know 🙄
A "nip" is when you tighten it by hand and then use a wrench or spanner to turn it another 1/2 to 1 full turn.
Which amazingly is exactly 11nm as it should be for an oil filter 😁
Will the owner be informing the dealter? I'm bloody sure I would! Oops, I see they've gone belly up! Colour me surprised!
:mad:
Thinking about it, its not the tightest, you got the fucker off!
The tightest one is the one you cant get off
I'll get my coat ....
