There goes my final drive
And the brake caliper fitted okay?
" There is a Chap "
in Middle England that will rebuild the rear drive for a GS1200
using BMW Parts ... and he will give Warranty for 12 Months
as a side issue he will shim to closer tolerences so they will be less snatch in the drive train ... and for this the price is
£440.00 + Vat @ 15% - for a GS1200 on a replacement basis
if you want he can insert a drain plug at the bottom of the casing to help overcome this problem in the future
drain drilling and plug extra
for a hp2 as he has no core units to replace at present it will be ship and when repaired he will return
or maybe drive in get repaired fit and drive out
in the early stages at present , but a bit cheaper than the alternative and 12 Months Warranty
pg
