sniffy
Can the 400 be upgraded to the 550 spec?
What are the main differences does not seem to be many looking at the Garmin website except no Blue tooth?
cheers
Andy
Cant find them on the Halfords web page....
A lot depends on where you bought it - as to the course of action.........
If it is a dependable re-seller - you should dispute the item.
If you think you have indeed been ripped off, then you can upgrade the UK/Ireland mapping on the 400, to full European mapping for £38 (I think).
You must use a Garmin application called "Mapinstall" to do this, otherwise it will simply update the UK/Ireland maps.
The 400 stores maps on SD card, has no bluetooth facility, and comes with less brackets/mounts than the 550.
Hope you get a satisfactory result.
Al![]()
Yeah you won't. Go into or ring your local shop and they can tell you which stores have them available. I know there are two in Truro and one in plymouth... or at least there was last week. As they are old stock they thend to be kept 'out back'... not sure how that sells them if I'm honest!
You may just be seeing the European basemap, this is a coarse map with just main roads that aren't necessarily in exactly the correct place. You can navigate using the basemap but not very satisfactorily.it has no SD card in it but appears to european maps in it.....
Try zooming in on say Paris and see if you can see all the minor streets, try the same on London. If it lacks detail in Paris but you can see lots for London then you probably have UK mapping, if neither have detail then you have no mapping worth mentioning at all.
is it possible to update maps without the orginal CD or code?
