Had this 2011 GSA for a few weeks now and it sure likes to drink petrol.
The last 3 fill ups have been at 220 ( ish ) miles and it's taken 31-32 liters. That's 32mpg
Only mod to bike is the exhaust flappy valve has been removed. Bike seems to run ok, idles smoothly and has plenty of go. I've looked at the air filter which is probably original ( 18000 miles ), little bit grubby but I've seen worse, blew it through with the air line and very little came out. Checked the plugs which offered a clue as the throttle side ones were black and sooty, the clutch side ones had brown deposits so look ok. I swapped them over and after a tank of fuel the throttle side ones have turned black and sooty. Clearly this pot is getting an excess of fuel.
I have a GS911 so I've did the idle calibration and engine sync, they were a little out but not much. The only fault code stored was the missing exhaust flap. I also reset and re-registered the adaptation values, very little change. Another tank of fuel confirmed 32mpg and black sooty plugs on the throttle side.
I had a look at the real time values on the GS911 and noticed that the lambda sensors are reading markedly different values, the throttle side pot much higher. Also the fuel trim for the throttle side is 3046% while the other is 0.6%. Bit of a difference there. After swapping the lambda sensors over both fuel trim values are now in the mid 3040's. I'm thinking bad lambda sensor and the throttle side pot has retained the old trim value.
All thoughts and opinions will be appreciated.
