jonogs
Help
Being a semi-competant mechanic I decided to have a go at a balancing the TBs as per the advice given in Rob Lentini document I got off the web a few years back.
So far I have built my own manometer (4m of tubing half filled with light oil - watch those exhausts though!!!) and adjusted the throttle stop screws so that I have a fine idle balance. (With brass bypass screws at 2.25 turns from seated) My trouble occurs when I try to raise the rpm to balance at about 1500rpm.
The initial pick-up of the engine buggers up the level in manometer such that any balance is virtually impossible. Any advice? How do I adjust the cable ends to begin the procedure? All loose with 1mm of play?
I have also discovered that if you back off the LHS stop screw you run off the TPS range and it doesnt run at all!!
Please resist the urge to be sarcastic as it take too long to read
