Had the throttle body ticking noise a long time ago. Fitted a ticker killer and all was good.
But have had a noise that I thought was another loose push rod end, (had a bad one before) so checked for this today, can't find a problem in there this time.
So Took it for a 50mile test ride and the noise came back.
Low idle, only when it warms up, sounds like valve train or small end. Runs great at speed and no noise, apart from the normal 126k engine noises.
One hell of a noise, probably only because I am listening for it.
Anyway, at some point I held the cable cam on the throttle body just see if that was where it was coming from, noise greatly reduced. You can even feel the knocking.
Anyone had this and how did you fix it. I am guessing it's so worn in there the spindle kit won't fix it.
Off to Scandinavia in a few weeks so I want to sort it before I go.
