Throttle Body Rebuild
Geno
Northern Ireland
Just fitted new bushings and new spindles , the fix was easy ,it took longer to read the How To . Havnt fitted them yet so cant comment if that dreaded rattle has gone from the right hand side . Will write up the rest when i get her back up and running ,plus setting to the 0.037 with multi meter .
All the way from Romania
Where did you get the bushings and spindle from?
Spotted this kit on the US site , from a guy called Cata Dan . Was real pleased when all the ticking has gone . Was able to get a very good set up on bike . Sounds so much better and stronger , but not cheap ,$117 dollars for both sides and postage . So watch the Dollar you might get a good price .
Machining the spindles is not that cheap either and nor are the other parts in the kit. Add that to a 25% raise in postal services that does not reflect in the end price. And it's still way cheaper than the Bing kit, as I have been told, reaching at 200$ + for both sides.
Glad your bike is fine now.
Dan.
