Hello all
When you do a TB sync using a GS 911, it locks the idle stepper motors while you balance the TBs.
I've read you can also do it by disconnecting the plugs from the stepper motors.
Can anyone tell me when the stepper motors are in the correct position to be disconnected, ie do they return to this position when you
switch off the ignition (after the bikes been running) or when you switch the ignition on and the bike goes through it's pre- start up checks.
Or does it make no difference, as long as they're disconnected.
Thanks.
Thanks.
