Hallo rossi1981
i will try to explain what i know about this effects (and i hope you need no perfect english language).
afaik, white foam on oil is often seen especially in colder seasons. A lot of members in other forums wrote also about. Little foam in the oiltank is also normal because it depends on the lubrication system of our engines. The second oilpump (from sump to canister) is sucking oil and also little amount of air. So after stoping engine there is alwais foam on the oil in the canister.
Now to the noise. In our engines is a build in decompression system which works at lowest revolution. So you can hear sometimes clacking sound while starting or stoping the engine.
Cheers from Germany
Nobu
