tex999
Help,
finished work last night, started my 1100. started fine ticking over ,then when i turned throttle to move away it died on me. left it a couple of minutes , started it idling ok, both cylinders firing as both header pipes getting warm, fuel pump running fine. again as soon as i moved throttle it died. cables are seated correctly, vacuum nipples both fine, both injectors spraying fuel. at a loss any ideas?
