Tomtom Rider 2 on a Migsel articulated mount?
Jumpjim
Sussex, England
I've just bought a rather lovely R1200 GS which has one of the Migsel articulated aluminium GPS mounts already fitted.
Will a Tomtom Rider 2 mount to it without too much trouble? I see the mounting plate at the back of the Tomtom has 4 screw holes and was wondering whether these match up with the pre-drilled holes on the mounting plate on the mount?
This is the mount I'm talking about...
Migsel's words says ..
* the Garmin Zümo cradle fits straight out of the box, screws are included with the mount
Tom Tom Rider 2 cradle has a four hole AMPS fix pattern (4 holes on pitch of 38mm x 30mm). So my guess its matrix of holes matches or lines up.
As Garmin Zumo and TT Rider 2 have same AMPS hole fix pattern, then you should be able to do the same but with longer M3 screws and washers.
