Too Much Oil
High oil level - been there, done that.;)
If the level is visible with the engine running I wouldn't panic you're probably 250-300ml overfilled, but for peace of mind its probably best to let the engine cool then drain a wee bit out via the sump drain plug (wear gloves, oil is a known carcinogen).
I would not normally advocate putting drained oil back into an engine but if you need to, be sure to use a spotless container and clean around the sump plug before removing to ensure no grit etc can get washed down into the oil you collect.
Castol Power 1. Fully Synthetic 10w-50.
There's the source of your problem.:blast That oil is thicker than 20-50 and therefore each litre takes up more room in the crankcase. So it will show up higher on the sight glass:augie
Do not worry about it - When you put in the bmw specified quantity of oil it fills up above the oil sight glass.
A mug full of oil over is absolutely nothing to be concerned about.
Just back from the pub....everything seems much clearer now...is that normal ?
I will check it again in the morning and I think I will end up draining some out.
Am suprised I have not got more more flack, even my wife called me a 'numpty'.
By the way the mug size was a large tea mug type afair.....but this is just a guestimate based on what was in the bottle of oil pre 'filling' as opposed to what was left in the oil bottle 'post-filling'.
Many thanks for all the replies.
Regards
CB:thumb2
Just to make you feel sooooo much better then "YOU NUMPTY" ha ha!!!!
Better to be safe than sorry and drain a little
spike
As steptoe says, a "mug full" is bugger all. Just ride the bike :)
