From closed butterflies, the 'against stop' opening of the left hand butterfly is set using the TPS to give you the open angle and then the 'against stop' opening of the right hand TB is set using the left hand as a fixed reference (both with equal air screws of course).
However Roger 04 RT who posted earlier in this thread has done some excellent research and work on oilhead fuelling - I think his findings indicate that the base line TPS voltage shouldn't be the usually accepted .371V
But why did you do a zero-zero in the first place - did you suspect bad throttle stops?
